NeilMac wrote: 04 Mar 2019, 12:14
Got it loaded onto the laptop, managed to get it to see my flight sim TX and also to calibrate it in joystick, but I don't seem to be able to get the sim to see the joystick.
I'm obviously doing something wrong, I just can't figure out what.
Click on the settings icon (the sprocket) then click on "Joystick" at the far top right.
You then map the joystick (or tx) - you'll find that joystick 0 = channel 1; joystick 1 = channel 2 and so on.
Starting with joystick 0/channel 1 move the "Map to" to select what it controls, so for ailerons it'll be "Roll" or for rudder "yaw"
Next step is to calibrate:
Make sure the stick is centred and click "Press when centred"
Hold stick to left and click "Press when left or down"
Hold stick to right and click "Press when right or up"
Do this for each of the channels you'll use, click back and you should be good to go
