Page 2 of 2
Re: Simple PWM display
Posted: 18 Aug 2019, 15:31
by RON
They are perfect for SC Transmitter meters, so small, they mount on the back of a 0.96 oled and don't take any room up
Posted: 19 Aug 2019, 18:10
by tiptipflyer
Thanks Phil for this little project. It works great.
Mine did not need any pullup-resistors.
Posted: 25 Aug 2019, 19:12
by RON
here is a slight variation to Phil's simple tester,
using a128x64 oled, I've incorporated a rx battery level meter too.
Notice this Oled is the split screen yellow/blue version which works nicely on this one
Posted: 19 Nov 2020, 07:44
I made one too! I added the pull up resistors "just in case". So simple yet so useful.
A great little device I must say :P
Posted: 21 Nov 2020, 18:01
by Mosfets
I also made one, it is a really useful design.
I found that if powered by a battery alone it would give erroneous readings if my hand was near the connector but adding a 10k pull down resistor cured that problem.
I chose to box mine with a cheap and cheerful servo tester. The PWM meter is on its flying lead still so I can monitor either a receiver or the tester output.
Posted: 21 Nov 2020, 22:48
Ade, I like it! I have the same cheap & cheerful server test - gotta love that Engrish :lol: :lol:
Posted: 19 Dec 2024, 08:38
A bit late to the party but just made one. Brilliant little widget .
I needed the pull up resistors on mine as it kept locking up.
It's about as simple to construct as an electronics project can be.
