Page 1 of 4
Flight Link Control Series 4 Restoration
Posted: 21 Oct 2020, 08:22
by stuart mackay
Here we go, guys, another really long shot!?!
Has anyone got a switch, throttle lever and end cap for a single stick series 4 or Sovereign, trying to resurrect one here and these bits are missing or broken.
Re: Flight Link Control Series 4 Restoration
Posted: 21 Oct 2020, 08:25
by stuart mackay
stuart mackay wrote: 21 Oct 2020, 08:22
Here it as received
Posted: 21 Oct 2020, 16:18
by stuart mackay
Stripped the case back to its bare resin, so here is a before shot!
and with a coat of primer, sanded ready for colour coats.
Posted: 21 Oct 2020, 22:48
by RobertC
I used to love these sets, the servos and receiver always looked so neat with the multicore covered cables they used...
I'm pretty sure this stuff was made in Gants Hill, Essex, Just outside Ilford.. I seem to remember visiting a model shop on Gants Hill roundabout must have been 52 year ago or so , or around 1968 /1970 .. who sold this very exclusive and expensive equipment
Posted: 22 Oct 2020, 03:40
by stuart mackay
RobertC wrote: 21 Oct 2020, 22:48
Posted: 22 Oct 2020, 08:26
by RobertC
Ahh Thank you
Well there you go live and learn
Now was this the same as RCS then ?
The mystery deepens
Posted: 22 Oct 2020, 08:35
by stuart mackay
RobertC wrote: 22 Oct 2020, 08:26
The mystery deepens
RCS headquarters/main shop was in Bath Road, Hounslow and, as far as I know, was an entirely different set up to FlightLink run by Idris Francis at Bristow Works, Hounslow. They shared the same same London Borough though.
Posted: 22 Oct 2020, 09:26
by RobertC
Thanks for the info Stuart, there was a lot of good ‘Made in Great Britain ‘ Back in the 60’s 70’s 80’s, sadly not now as far as I know , and by the looks I’m not knowing much at all lately
Posted: 22 Oct 2020, 15:14
by stuart mackay
Had a play last night with trying to fix the seized switch which I ended up replacing with a JR/Futaba proprietary slide switch. Also made a replacement throttle arm from 3mm Composite sheet to match the. original one.
I tried to planish the dent in the aluminium facia out, which I managed but trying to replicate the brushed aluminium finish with wire brushes proved elusive, so to conceal this and another couple of corroded areas, I resorted to a rattle can of aluminium paint, whilst not original made a better job of the ,otherwise, pock marked original brushed ali sheet facia plate.
Mike Kitchen came to the rescue (as always!) with a superb scan of his Series 4 lower black sticker, which I was able to get laser printed locally on self adhesive film and then laminated it with some clear fablon to get a better gloss and protect the inked graphics.
Pics below:
- Mike K laser printed scans
- new label and facia plate
- Damaged label
- New throttle arm fabricated from Composite sheet
- Finished facia ready to install
Posted: 22 Oct 2020, 16:06
by stuart mackay
Got the Tamiya masking tape and a rattle can out and here is the result
