50 years ago Phil Kraft published this
Posted: 02 Mar 2018, 14:01
by stuart mackay
Here are some pics to my homage to Mr Kraft's finest.
Kwik Fli 3 built from original Feb 1968 MAN plans from Outerzone.
Now 5 -6S electric with my original Kraft Tx converted to FrSky 2.4.
Ailerons and elevator servos on Y leads, weight 5 1/2 lbs.
Am 3D printing an Enya 60 to bolt on the nose.
Re: 50 years ago Phil Kraft published this
Posted: 04 Mar 2018, 21:02
by F2B
Well done! One of my all time favourites.
Seeing you took the example colour scheme from KF 3 nr. 2:
Posted: 26 Mar 2018, 18:16
by stuart mackay
The KF3 had air under under its wings for the first time this afternoon at the local field, flew perfectly on 6S, and was only drawing 28 A on the 11 x 7 APC E prop, have got a 12 x 10 to try and that draws 50 A on 6S.
Otherwise, nothing dramatic to report, roll rate and controls all well harmonised, couple of turns on one aileron clevis and flies just like I remember in the 70's, but just quiet! Will start moving C.G back from plan position on next flights over Easter as I have a small amount of down trim on the Kraft Tx.
Happy Bunny here :P
Posted: 26 Mar 2018, 19:36
by F2B
Congratulations! :D
Bruno
Posted: 26 Mar 2018, 19:37
by Igull
stuart mackay wrote: 26 Mar 2018, 18:16 flew perfectly on 6S, and was only drawing 28 A on the 11 x 7 APC E prop, have got a 12 x 10 to try and that draws 50 A on 6S.
Looks really nice Stuart, what motor did you fit, be interesting to run it through ecalc ?
BTW, a 3D printed Enya will just melt with all that methanol about :mrgreen:
Neil
Posted: 26 Mar 2018, 23:13
by stuart mackay
Igull wrote: 26 Mar 2018, 19:37
Neil
this is the one in the KF3
https://www.der-schweighofer.net/Electr ... 0KV-a90289
Posted: 08 Apr 2018, 22:58
by stuart mackay
Got some air under her wings at weekend
Posted: 09 Apr 2018, 07:53
by PaulJ
Lovely, well done! I am sure PK would be delighted to see it. :P
