Need advise to Integrate Phil S/C encoder to Lemon DSMP Transmitter DIY Module
Posted: 10 Jul 2024, 10:22
Hi all:
Currently I am assembling a Phil Encoder with Lemon DSMP Transmitter DIY Module. I would like to seek advise and guidance on the following: -
1) Lemon Module instruction manual specific that the module and Antenna / Cable should be sited away from any metal plate. Based on my configuration (See attached photo), the module will be mounted close to the Push Button Switch which has a metal plate. Route of the Antenna Cable is also close to the switch. Should I change the location of the module and cable to avoid any possible interference?
2) What is the best way to mount the module after binding with receiver. Can I shrink wrapped it then mount it to the plastic box using double sided tape?
Thanks
Thanks
