Would you like to re-phrase that Phil?
Gary
In case (?) anyone is about to make a Pixie enclosure, I've just modded the case to accept a 20mm brass M3 hex standoff at Ron's suggestion. The thread was stripping out after some minor use. There's now a c'sk 3mm hole in the case rear to accept a c'sk M3 screw - still a bit of a post inside to offer some support.Igull wrote: 21 Mar 2018, 22:20 The whole design is now open source and you can download all of the files from Thingiverse - https://www.thingiverse.com/thing:2835200
