Wanted.. 300 watt 28-34. 28-36 size motor 1600kv. Or similar
Re: Wanted.. 300 watt 28-34. 28-36 size motor 1600kv. Or similar
Metal wing bolts??? It's going to need a metal wing SPAR!
The guy who designed it wanted a modern version of the Sharkface..
Nothing wrong with the old sharkface.
Motor is on its way, Shaun. Should be with you by 1300 Friday. Will PM tracking number.
Shaun,
I have one of these in my box of motors. 3500 KV
https://www.manualsdir.com/manuals/5911 ... 500kv.html
Thanks for the offer Alex but it's too high KV to drive the prop size I need. I have a motor to try out coming from Pete so hopefully that will sort it.AlexC wrote: 31 Mar 2022, 12:11 Shaun,
Had 3 great flights today. At 350 watts it's truly rapid and the 2500kv motor with a 6*4 prop emits an excellent scream.
Had a lucky escape on the last flight as the elevator servo wasn't happy and started sticking...should have used a metal geared one. All the high G lunacy rogered it but got it down in one piece.
