I've converted a number of single or double-stick Kraft transmitters (8 or 10 ).Ginger wrote: 09 Jun 2022, 09:47 Some meter coils are quite a high resistance in themselves, yours must be 3.5k which is unusually high but they do vary from make to make![]()
The meters have an internal resistance of 2.7k to 2.8k.
When using a 6-cell NimH battery, no need for any zener diode when you have available a perfectly good regulated 5V on the coder..
I connect the positive of the meter (left tag seen from inside the transmitter box) to the switched 7.2V on the power switch, and the negative (right tag) to the +5V regulated voltage on any free connector of the coder.
In some cases, I've added a regular diode (1N4148) in series with the meter.
That's what works for me, I like KISS.
