Graupner/Grundig Varioton 2 and kinematic actuator
Just arrived from a Belgian friend!
Thanks Herman!
Let me know if anyone needs detail photos?
Please keep them under 1MiB
Re: Graupner/Grundig Varioton 2 and kinematic actuator
Nice toy Stu.
That is the rare two channel version for just rudder. Nice Catch.
Stuart, I think you are missing one bit for the set, the Variophon channel 1-2 filter module that plugs into the Rx. The Kinematic then plugs into the 1-2 filter module (green if I remember correctly) , unless the Rx is different to all other Variophon sets and had it built in (I only have the 4, 8 and 10 sets, I don't have a 2 like yours).
I'll see if I have a spare channel 1-2 filter, it probably doesn't work but at least it would complete your set
Post by Pchristy »
I agree with Mike! What you have in the picture is the super-regen receiver (broadband, covers the whole 27 MHz band!). The Superhet receiver was about twice as thick - a double deck design.
The filters to identify the different tone frequencies were plug in modules, the same size as the super-regen receiver, but different colours.
Here's a picture of my 6-channel set. You can see the receiver stack (Superhet receiver plus three 2-channel modules plugged in) along with the original super-regen receiver module:
The filter modules contain two relays.
Because the filtering was electronic, rather than using a mechanical reed-bank, they were much more reliable than the American sets. However, they also used a greater spread of audio frequencies, getting up to just shy of 10 KHz. This meant they couldn't be sold in the USA, where everything was meant to fit in a standard audio bandwidth, with an upper frequency limit of around 3.4KHz.
Worked brilliantly in the UK though!
:lol:
What is missing is the green filter module for channels 1 and 2.
Thanks Guys, interesting to see your comments and if anyone does have the parts to complete the set, then your assistance is much appreciated! :P
The price is a bit too high, but this is what you need.
https://www.ebay.de/itm/165643418522?it ... BM1v-NsO5j
MaxZ
Post by MaxZ »
tiptipflyer wrote: 13 May 2024, 18:32 The price is a bit too high, but this is what you need.
The description is ambiguous, it is not clear if it is in working order....
Pin heaers corroded due of the foam...
