Page 1 of 3
Slim Jim servo instructions & Single Channel receivers
Posted: 11 Nov 2023, 16:10
by Malc2770
Hello, I am new to the forum and not sure how it works! I am trying to get my model boats going again after a 50+ years break. I am looking for Slim Jim servo instructions as I can not remember how to connect them up (Does anyone have a copy please). Also I have vairious single channel Transmitters with no Receivers (Does anyone know of a source of crystal controled relay 27mhz receivers). I hope this message works and look forward to any replies, Malc.
Re: Slim Jim servo instructions & Single Channel receivers
Posted: 11 Nov 2023, 21:43
Hi Malc,
Welcome to our retro Valhalla.
Which version of the slim Jim instructions are you looking for.
There were at least 2, possibly 3 versions.
Any particular brand of 27mhz s/c rx you are looking for?
Posted: 12 Nov 2023, 17:09
by Malc2770
Hi Shaun, Thank you for your reply, I am still sorting out how the forum works, but getting there slowly! I have several Slim Jim servos but no idea which models, some have 3, 4 or 6 wires to connect (does that give a clue)? I also would like to use my Gem and RCS transmitters but am not worried which receivers to use. Crystal controled would be best so I can sail with other club members and a total of 4 Rx`s would be great so I don`t have to keep moving from boat to boat. By the way I am quite happy to pay any costs involved if you can help, Malc.
Posted: 12 Nov 2023, 17:40
I'll have a look and see if I have any spare relay rx's in my bits box.
Posted: 13 Nov 2023, 13:23
Posted: 13 Nov 2023, 13:27
Slim jims were odd because you pressed once for left , twice for right. The opposite of all escapements such as Elmic.
There was a version of the slim Jim for relayless rx's
Rgds,
Posted: 13 Nov 2023, 14:32
by Spike S
Shaun wrote: 13 Nov 2023, 13:27
Resolved simply by moving the output crank (at either the motor or rudder) by 180 degrees on the shaft, Nest'ce'pas ?
Posted: 13 Nov 2023, 14:46
Yes ,they chose to be different.
The slim Jim was intended to be installed like a traditional escapement using a torque rod (see diagram,) not via a pushrod. I seem to remember also that the output shaft had a flat on it keying the arm in one position. Moving the out put arm wouldn't change the direction of rotation. In a boat however you could easily change direction with a push rod. A few Japanese motorised actuators also used this key sequence.In fact one set up was. 1st press left, 2nd right, 3rd up, 4th down, 5th throttle change... No quick blip. I set one up to see and glad I didn't try it in the air. Not easy to get the throttle correct. ..
Posted: 13 Nov 2023, 16:52
by Malc2770
Hi Shaun, Thanks for the diagram, I am sure I can get them working from that. I will keep my fingers crossed regarding the receivers. Best wishes, Malc.
Posted: 13 Nov 2023, 20:22
Shaun kindly gave me a Slim Jim to go with my Astral Tx a while back (both made by Modelectric Ltd), so here are some pictures and a scan of the instructions so you can all see what one looks like
And I found a spare label for the Tx on eBay recently, quite a bizarre find
