This was originally built as a 35 MHz set, with an Ace Silver Seven encoder. I had intended to keep the encoder when I converted it to 2.4 GHz, but it had developed a really weird fault which I failed to locate. As a result it now has one of Phil's excellent 7 channel Arduino encoders, on a DIYMore "Strong" board.
Power is provided by a couple of LiIon cells salvaged from an old laptop pack. All the "blue bits" used for the aerial, meter and RF board mountings are diy 3D printed.
I've owned it from new. Before I could afford a proper helicopter transmitter, I used this, with a changeover switch changing the throttle function between the left stick and one of the auxiliary sliders. This enabled me to have a crude "idle-up" function for aerobatics, as well as a throttle hold for auto-rotations, though it did require a bit of digital dexterity to switch between the two....!
In fact, my son used it at a Hirobo Cup event for his first contest with a 60-sized helicopter, back in the early 90s! He borrowed my Hirobo Condor, as a more fitting machine than his Shuttle, for the aerobatic event. Unfortunately his competition flight came to a premature end when the 90 degree adapter needed to fit the silencer to the engine fractured in flight, resulting in the engine stopping half way through his roll! He did succeed in righting the helicopter, and carrying out an unexpected auto-rotation, landing it safely, with no damage! He didn't get many points, but he did get the biggest round of applause of the day!
He also won a newly announced OS61 SXH helicopter engine in the raffle, before they'd even appeared in the shops! He always was a jammy little so and so....! The poor old Condor never knew what hit it when that was duly installed!
The transmitter now has a multi-protocol board for the RF module. Unfortunately, its only an ATmega one, with limited storage space, but I've managed to get all the FrSky and Spektrum protocols in, which is all I need.
As an aside, the STM32 MPM boards seem to be pretty much unavailable at present. Neither Banggood nor AliExpress appear to have any. Presumably they are all being snaffled up by the likes of Jumper and RadioMaster.....
And finally, that Condor helicopter survives to this day, sitting on a shelf in my garage. I really ought to see about bringing it back to life again.....
