FUTABA 2 ch M series convert to 2.4
Barney
Post by Barney »
Hi there,
Hope you guys can help. As stated in the title,I wish to convert a Futaba 2 ch M series to 2.4 using a FRSKY hack module. Could I :
1, find the ppm output on the existing Futaba board and make the FRSKY connection there and somehow disconnect the rf section or
2 , remove the Futaba board altogether and use a new encoder.
I look forward to your replies, the simpler the better please as this 70+ brain is getting more addled by the day!.
Rgards, Barney
GarydNB
Re: FUTABA 2 ch M series convert to 2.4
Post by GarydNB »
I did exactly what you propose in option 1 and it works perfectly....and I know absolutely nothing.
Gary
P.S. mine was a four channel set....someone will surely point it out of that will make a difference.
