A little while ago I dropped a 2.4Ghz Radiolink T7F down two flights of stairs onto a hard surface (as you do
Now, no spare aerials for the T7F are advertised. But there IS a cheap one for the Radiolink A10 - with the right push-fit. https://www.ebay.co.uk/itm/Radiolink-Re ... SwQiFaYFwi
It's different inside - it has a PCB aerial rather than the wire one of the original. (The one I got is different to the ebay picture) But its physical fit is perfect, including the cable connector.
My question is - Is there any reason why this might not be compatible?
For 27Mhz sets you need to tune the aerial to the right length, and even if you got a replacement that was nominally the same it would make sense to check the balance before using it. But as far as I can see, all 2.4Ghz sets use the same antennae, and so an aerial for 2.4Ghz ought to do any service - even wi-fi. Unless, of course, someone here knows different...?
